Bug in Optimizer at CompareBlock?
wsandor
Gepostet: 21.10.2024 - 16:54 Uhr  ·  #1
In my program, I use CompareBlock. It works normally until I run the Optimizer. With the optimized code, it always gives a False result.
I've checked the generated asm files and find that with the optimizer, only the first variable's addres is set, so it will always compare with a rendom memory area.
I atttached a very simple test program and the 2 asm outputs.
I use compiler ver. 6.00.00, optimizer ver. 3.6.12.0
Do I something wrong or it isreally a bug?
And a smaller error in PED32new: If I open the About dialog a second time, then it doesn't write the compiler version and the dialog couldn't be closed, so it hangs the whole program.
Re: Bug in Optimizer at CompareBlock?
Gepostet: 22.10.2024 - 10:22 Uhr  ·  #2
It sounds like a bug.
I will take a look. But 6.00.00 is not the latest version.
The latest released version of the optimiser is 3.6.13.2
Gepostet: 22.10.2024 - 11:39 Uhr  ·  #3
PEDnew is very beta with many bugs. For that reason I reverted to the original PED as the default IDE in the latest release.
Gepostet: 22.10.2024 - 11:48 Uhr  ·  #4
@WSandor, could you provide the .dsm file for this simple project please? It will make it easier for me. Or the complete project directory would be even better.
Thanks.
wsandor
Gepostet: 22.10.2024 - 17:14 Uhr  ·  #5
Hi Merlin,
Thanks for your answer!
I've tried with the newest version (Compiler V6.00.05, Optimizer V3.6.13.2), the result is the same.
I've attached all the project files.
Best regards,
Sandor Wortmann
Gepostet: 22.10.2024 - 18:33 Uhr  ·  #6
Thanks Sandor
Gepostet: 23.10.2024 - 10:09 Uhr  ·  #7
Hallo Sandor.
I have examined your code and cannot see an error there.
I am not disputing that the error exists but is seems that in creating a 'small example displaying the error' you have removed the error. This can often happen with the optimiser.
Rolf always insisted on a small demo program, but I do not. If you can send me your original project where you noticed the error via pm, I will examine that. You may depend on it that I will maintain confidentiality of the code.
Please note, in case you ran this in the simulator, that the optimiser is aware that the variable b is not used and so will remove all updates to it. So the value of b will not change in the simulator.
wsandor
Gepostet: 24.10.2024 - 09:27 Uhr  ·  #8
Dear Merlin,
Thanks for your answer again.
I attachaed a "working" example. When I compile it without optimization, it blinks a LED - this is the normal behavior. When I optimize it, the LED doesn't blinks.
Unfortunately I run to a bigger problem: as you advised I reverted back to the original PED32 from PED32New, but I realised I can't program any projects from there. The Programmer always drop an error window that it doesn't find the project's hex file. I attached a screen capture from it. If I do the same from PED32New it works normally. Could you help me please, what could be the problem, because before the update everithing worked fine.
Sándor Wortmann
