Fehlermeldung in BootApp bei CalcFlashCheck_A
jomixl
Gepostet: 27.09.2018 - 09:52 Uhr  ·  #1
ich versuche gerade die Funktion CalcFlashCheck_A in einer BootApp zu verwenden.
Der Compiler meldet dann das Fehlen von "Boot_Init" und einiger weiterer Flashloader Funktionen.
Eigentlich möchte ich nur die Checksumme der App überprüfen. Ist CalcFlashCheck_A in einer BootApp überhaupt möglich?
Gruß Joachim
// This application runs completely in the boot section of the AVR.
// Some library functions and drivers are used and also interrupts
// are running. If the FlashDownloader is started then also here
// the standard interrupt driven UART/SerPort is used for communication.
// Please note that the constant "BootCheckF" is placed to a fixed
// address, but is outside of the boot area. A valid main application
// residing in the "normal" code area $0000 and up must provide this
// constant in order do an immediate jump to $0000 into the standard
// application area.
// The Main Application must be build and compiled separately and can
// be downloaded with this Application/Bootloader
program BootApp;
{ $WG} {global Warnings off}
Device = mega128, VCC=5;
{$BootApplication $0F000} // 8kByte Boot size
NoteBook = E;
COMport = USB2;
Supply = 5, 100;
LockBits0 = [BOOTLOCK11];
FuseBits0 = [];
FuseBits1 = [BOOTRST, BOOTSZ0, BOOTSZ1, CKOPT, JTAGEN, OCDEN]; // 8kB Boot
FuseBits2 = [];
ProgMode = JTAG;
ProgFuses = true;
ProgLock = true;
ProgFlash = true;
ProgEEprom = true;
// AddApp = 'c:\PROJEKTE\Pascal_sc\AVR\EvaBoard\AVR EvaBoardI';
// Info for programmer, joining hexfiles, using this project name
Import SysTick, FlashWrite, SerPort, BeepPort, SysLEDblink;
From System Import FlashCheck_A;
ProcClock = 16000000; {Hertz}
SysTick = 10; {msec}
StackSize = $0030, iData;
FrameSize = $0064, iData;
SerPort = 19200, Stop2; {Baud, StopBits|Parity}
RxBuffer = 8, iData;
TxBuffer = 8, iData;
SysLedBlink = 10; {SysTicks}
SysLedBlink0 = PortA, 0, high;
BeepPort = PortG, 4;
Dateiname: BootApp.pas
Dateigröße: 4.49 KB
Titel: BootApp
Heruntergeladen: 211
Re: Fehlermeldung in BootApp bei CalcFlashCheck_A
Gepostet: 30.09.2018 - 13:30 Uhr  ·  #2
Leider kann ich nicht weiterhelfen, da ich es auch nicht kompilieren kann und vermute, dass das in einer
leider noch nicht funktioniert.
Im AVRco Demo BootCheckSums machen die das mit
{$PHASE BootBlock $0F000}
und dort existiert auch ein
define
  FlashChkSum             = (2 * BOOTRST) -2;
womit klar ist, wo die Checksum im Flash liegt.
Ich musste allerdings das Demo mit
  _CalcFlashPageA := 0;
  _CalcFlashAddrA := 0;
  _CalcFlashCA    := 0
aufpimpen, damit es funktionierte. Siehe Democode BootChecksum fehlerhaft
jomixl
Gepostet: 04.10.2018 - 13:02 Uhr  ·  #3
danke, hab ich wohl gelesen, aber ich wollte die Funktion in einer BootApp verwenden.
.... muss ich jetzt wohl zu Fuß machen ...
Gruß Joachim
