I've just installed V6.00.04 version of AVRCO. Previously I used 5.10.00 for years.
I tried to compile one of my old programs with the new version and run into a probem: On ATMega128, if LCDPORT is defined to PORTF or PORTG then the compiler throws an error: "Error: DEFINE LCDPORT = PortX (x defined in *.dsc) expected". PORTE or lower doesn't give an error.
The error could be reproduced with a minimal, project wizard generated file I attached.
Any idea about what can be the problem?
