Optimiser
Optimiser
Gepostet: 13.09.2021 - 09:54 Uhr  ·  #1
It has been a while, but a couple of bugs have been found in the optimiser, one to do with very large 64 bit numbers (>$7FFFFFFF) and one to do with loops within a 'with' statement within a loop.
Updated optimiser attached.
Dateiname: Optimiser.zip
Dateigröße: 422.13 KB
Heruntergeladen: 153
Re: Optimiser
Gepostet: 13.09.2021 - 10:46 Uhr  ·  #2
Hello Merlin, something is wrong with your update, I am getting wrong values from my DHT22 humidity / temperature sensor.
Humidity = 11.6%
Temperature 14 degrees
Without your optimiser 59.7% and 22.9 degrees.
Greetings Frank
Hallo Merlin, mit deinen Update stimmt etwas nicht, aus meinen DHT22 Feuchte / Temperatur Sensor bekomme ich falsche werte.
Feuchte = 11,6 %
Temperatur 14 Grad
Ohne deinen Optimiser 59,7 % und 22,9 Grad.
____________________________________________
PS...
Can of course also be due to my timing program code from the DHT22
Kann natürlich auch an mein Timing Programm Code vom DHT22 liegen
Re: Optimiser
Gepostet: 13.09.2021 - 16:48 Uhr  ·  #3
Hi Frank. If you send me your project via pm, I will take a look.
That could, of course be possible. Optimised code does run faster than unoptimised...
But either way, if you send me your project and indicate where it fails I will take a look.
Re: Optimiser
Gepostet: 14.09.2021 - 17:17 Uhr  ·  #4
Der Optimiser ist ok, lag an meinen Timing :-)
