Extending toggle procedure to boolean
Gepostet: 06.03.2019 - 12:12 Uhr  ·  #1
Toggle( x ) applies to byte, bits and bitfields. Other structures including boolean are prohibited. I would like to see toggle( boolean ) implemented. I would be happy for it to be identical to toggle(byte).
Re: Extending toggle procedure to boolean
Gepostet: 13.03.2019 - 09:45 Uhr  ·  #2
I wrote a
procedure toggleb(b: Boolean);
if b then
b:=false;
b:=true;
to do just that :-)
Gepostet: 13.03.2019 - 14:05 Uhr  ·  #3
Oder
b:= Not b;
Aber was solls. Toggle(boolean) ist jetzt implementiert!
Sie readme File
Gepostet: 13.03.2019 - 17:34 Uhr  ·  #4
oder letztlich nix weiter als ein
b := b XOR $FF
Gepostet: 30.04.2019 - 14:33 Uhr  ·  #5
Hi Gunter.
I wasn't meaning to ask to toggle byte - I thought that was already there (I misread the manual).
Often I have something like
MyVar[@MyByte, 3] : bit
and then in several places
Toggle(MyVar);
I had occasion to redefine my bits as boolean by redefining MyVar as
MyVar : boolean
For the most part that was all I needed to do, because largely bit and boolean are treated the same, but
Toggle(MyVar);
was not valid. Hence my request.
Gepostet: 30.04.2019 - 14:58 Uhr  ·  #6
Hello Merlin
a BIT is handled more as a Funktion than a simple VAR. This makes it impossible for using the toggle Funktion.
Gepostet: 30.04.2019 - 16:35 Uhr  ·  #7
Hello Rolf.
Sorry, I don't understand. I use toggle with bits all the time.
E.g. from actual code:
  External_Watchdog [ @PortG, 4 ] : bit;
  Toggle( External_Watchdog );
Ahhh... you mean the BIT( var, n) function. No I did not mean that.
Gepostet: 10.05.2019 - 22:43 Uhr  ·  #8
Hi Rolf,
ich hab grad eben
    If DispInvDo=true
      then
        DispInvDo:=false;
        Toggle(DispInv);
        SetMode(DispInv);
getestet und es funktioniert nicht.
So geht es aber:
    If DispInvDo=true
      then
        DispInvDo:=false;
        If DispInv=true
          then
            DispInv:=false;
            DispInv:=true;
        SetMode(DispInv);
Mit deinem, wie oben geschrieben
DispInv:=not DispInv;
funktioniert es auch.
XMega256A3U
Version 5.10.01
