constant array without coded number of elements
Gepostet: 16.06.2014 - 14:06 Uhr  ·  #1
I am trying to enter constant array of some type, where I would enter all elements in code. This works fine if I enter the number of array elements (like with MyArr: array[1..3] of TPoint), but I will maintain an array in code that will grow in elements. Sometimes I will have to add 5 elements, sometimes more. Right now I have to increase manually higher array index. I have tried various methods trying to avoid this, but no luck. Is there some way to acomplish this? Something like M5Arr: array[] of TPoint?
  TPoint = record
    X, Y, Z: integer;
  APoint: TPoint = (X : 0; Y : 2; Z : 4); // compiles
  MyArr: array[1..3] of TPoint = ((X: 0; Y: 2; Z: 4), // compiles
                                  (X: 5; Y: 1; Z: 0),
                                  (X: 2; Y: 2; Z: 2));
  M1Arr: array[1..SizeOf(longword) div 2] of byte = (2, 3); // compiles
  M2Arr: array[1..High(M2Arr)] of TPoint = ( // internal compiler error
                                  (X: 0; Y: 2; Z: 4),
                                  (X: 5; Y: 1; Z: 0),
  M3Arr: array[1..Length(M3Arr)] of TPoint = ( // internal compiler error
                                  (X: 0; Y: 2; Z: 4),
                                  (X: 5; Y: 1; Z: 0),
  M4Arr: array[1..SizeOf(M4Arr) div SizeOf(TPoint)] of TPoint = ( // internal compiler error
                                  (X: 0; Y: 2; Z: 4),
                                  (X: 5; Y: 1; Z: 0),
  M5Arr: array[] of TPoint = ( // identifier expected error
                                  (X: 0; Y: 2; Z: 4),
                                  (X: 5; Y: 1; Z: 0),
Re: constant array without coded number of elements
Gepostet: 16.06.2014 - 17:07 Uhr  ·  #2
Hello Avra,
we don't have variants here. Furthermore we have an one-pass compiler.
So most of your constructions will not work.
Very strange is "length(array)". An array doesn't have any length, only sizeOf.
But SizeOf can only work with an already defined type,var/const.
Gepostet: 17.06.2014 - 00:21 Uhr  ·  #3
Well, I will then have to recalculate array length manually after each change. Anyway, hope that something similar to const Arr: array[] of TSomeType =(...) is possible was not big.
While doing a little research about the topic, I have tried few things found. One of them was to see if at compile time I could use Length() of an array demonstrated in runtime use at the end of this article:
http://www.delphibasics.co.uk/Article.asp?Name=Arrays
As you could see from my unfortunate trials, I was pretty desparate... :banghead:
Gepostet: 17.06.2014 - 23:24 Uhr  ·  #4
Not a lot of help but the compiler can do some calcs for you, so if you have
  cArrayLen1 : word = 3;
Myarray[0..cArrayLen1] of point = ....
and you want to add 3, you can put
  cArrayLen1 = 3 + 3;
then to add another 5
  cArrayLen1 = 3 + 3 + 5;
No very elegant but....
Gepostet: 20.06.2014 - 01:05 Uhr  ·  #5
Thanks for the effort Merlin, but I was hoping that it could be done in a more convenient way. In Arduino I can write this without specifying number of bytes in advance:
byte arr[] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
I know that single pass compiler is not convenient for this, but I was hoping that something already exist since we already have
const arr : array[1..8] of byte = 'FileName.ext';
I wouldn't even mind if I could reserve more then entered array elements (which should not be a problem for single pass compiler), but unfortunately this is not valid since compiler asks for all 8 array elements:
arr : array[1..8] of byte = (11, 22, 33);   //  <<< ERROR
On the other hand, this is not a show stopper so I will learn to live with it.
