Convert Float (or Integer) to Byte array
AV
Gepostet: 03.12.2012 - 15:55 Uhr  ·  #1
I want to convert a Float (and Integer) value to a Byte array.
Or in other words:
The Float numbers are internally represented by 4 Bytes and Integer numbers by 2 Bytes.
These Bytes I want to copy into a custom data frame (encoded as Byte array) and send it by UDP (using TINA).
After some searches I found the Pascal command move, which could be used for the conversion task.
The AVRco compiler manual just has a side note that the move command is supported.
Unfortunately the compiler doesn't like my code and I didn't find any AVRco related information in the web.
// definition
testFloat :Float;
floBytes  :Array[0..3] of Byte;
// conversion test
testFloat := 3;
move(testFloat, floBytes, 4);  // ERROR: var or symbol expected
I would be happy about some hints.
Re: Convert Float (or Integer) to Byte array
Gepostet: 03.12.2012 - 16:03 Uhr  ·  #2
I use the AVRco Command CopyBlock:
testFloat :Float;
TestFloat := 3;
CopyBlock(@TestFloat,@FloByte[0], SizeOf(TestFloat));
Regards, Michael
AV
Gepostet: 03.12.2012 - 16:31 Uhr  ·  #3
Good Boy - thank you (-:
Andreas
Gepostet: 03.12.2012 - 16:32 Uhr  ·  #4
was spricht gegen
testFloat :Float;
floBytes(@testFloat) :Array[0..3] of Byte; //overlay
Braucht keinen Speicher und keine Laufzeit.
Gepostet: 03.12.2012 - 16:40 Uhr  ·  #5
Was dagegen spricht? - Die runden Klammern um den @-Ausdruck! :P
Sonst nix! Ist bei einfachen Ausdrücken der bessere Weg..
Gepostet: 03.12.2012 - 16:41 Uhr  ·  #6
einmal nicht nachgeschaut :sick:
Gepostet: 03.12.2012 - 17:47 Uhr  ·  #7
You can exploit overlays as seen here:
  TFix64Overlay = record // this is handy for fast extraction of integer and fractional parts
                    fix        : fix64;
                    x  [@fix]  : fix64;
                    i64[@fix]  : int64;
                    w64[@fix]  : word64;
                    i  [@fix+4]: longint;
                    i32[@fix+4]: longint;
                    f  [@fix]  : longword;
                    f32[@fix]  : longword;
                    b  [@fix]  : array[0..7] of byte;
                    w  [@fix]  : array[0..3] of word;
In your situation it renders to something like this:
  TFloatOverlay = record
                    single        : float;
                    b  [@single]  : array[0..3] of byte;
  TIntOverlay = record
                    int           : integer;
                    b  [@single]  : array[0..1] of byte;
   OvrFlt: TFloatOverlay;
   OvrInt: TIntOverlay;
   FirstFloatByte, SecondFloatByte, ThirdFloatByte, FourthFloatByte: TFloatOverlay;
   FirstIntByte, SecondIntByte: TIntOverlay;
  OvrFlt.Single   := 3.14;
  FirstFloatByte  := OvrFlt.b[0];
  SecondFloatByte := OvrFlt.b[1];
  ThirdFloatByte  := OvrFlt.b[2];
  FourthFloatByte := OvrFlt.b[3];
  OvrInt.Int    := -9876;
  FirstIntByte  := OvrInt.b[0];
  SecondIntByte := OvrInt.b[1];
AV
Gepostet: 04.12.2012 - 12:09 Uhr  ·  #8
It's interesting so see the different ways ...
