problem with LCD 4 x 20 + Atmega64
Peter KWS
Gepostet: 05.12.2011 - 21:35 Uhr  ·  #1
Hi all. I have a character display with 4 x 20 44780 controller and everything is ok but sometimes display shows random characters and I have to reset the mega64 that everything was ok: ( Connection is by DocuStdDriver.pdf, any idea what's is problem ? Display in a loop periodically rewriting new data in 50ms.
Re: problem with LCD 4 x 20 + Atmega64
Gepostet: 05.12.2011 - 21:48 Uhr  ·  #2
is it really a "44780" or a compatible one?
What is the cable length MCU-LCD?
Did you try slower refresh rates?
Peter KWS
Gepostet: 05.12.2011 - 22:08 Uhr  ·  #3
I find the display in google, display is Bolymin BC 2004B YPLEH with KS0066 controller, is this controller compatible with 44780? slower rate I tried and still angry :( For example, 10 min. works well and then go mad. It is connected to 10 cm long flat cable pc.
Gepostet: 05.12.2011 - 22:17 Uhr  ·  #4
first try
LCDtype = 0070;
and
LCDtype = 0073;
10cm flat cable is OK.
Peter KWS
Gepostet: 05.12.2011 - 22:26 Uhr  ·  #5
Ok thank you Gunter, tomorow i trying LCDtype = 0070 or LCDtype = 0073, write the result tomorrow, good night, bye. :-)
Gepostet: 05.12.2011 - 22:47 Uhr  ·  #6
or
maybe the power supply of the lcd is to weak.
Try to use additional thick cables and 10uF capaticors near the lcd power pins.
I am sure the AVRco lcd driver works without problems ->
must be something else!
Peter KWS
Gepostet: 06.12.2011 - 22:19 Uhr  ·  #7
Today in work i change the controller in program from 44780 to 0070, I gave capacitor to LCD VCC and all is ok, 10 hours test and work perfect, thank you Gunter for new knowledge :)
