CRC Stream
CrcCCITT
uli
CRC Stream
Gepostet: 08.01.2011 - 13:33 Uhr  ·  #1
sorry I posted this first in the wrong forum (software)
maybe somebody can give me an hint what I'm doing wrong here. I used this to calculate a CRC checksum:
test_string:='teststring';
CRCstreamInit($0810);
tst_crc:= CRCstreamAddP(@test_string, 10);
WriteLn(SerOut, 'CRC: ['+IntToHex(tst_crc)+']');
What I get is a "D91C", but the correct result should be "C02A" ( assuming the CRC start value is $0000, but even if I calculate with a start value of $FFFF and a seed/ poly of $0810 I should get $6068) so it doesn't add up.
I'm using Compiler Version 4.93.08 Date 080501
Any Ideas?
Uli
uli
this seems to work
Gepostet: 08.01.2011 - 17:56 Uhr  ·  #2
Ok,
I tried this and it seems to work:
function CRCString(pSData : pointer to string; seed : word; crc_init : word): word;
crc      : word;
i, j     : Byte;
crc:= crc_init;
for j:=1 to Length(pSData^) do
  crc:= crc xor (Word(pSData^[j]) shl 8);
  for i:=1 to 8 do
    if (crc >$7FFF) then
      crc:= (crc shl 1) xor seed;
      crc:= crc shl 1;
  endfor;
endfor;
return(swap(crc));
tst_crc:= CRCString(@test_string, $0810, $0000);
Not shure what or how exactly the CRCstreamAddP function calculates or if I was using it in a wrong way...
Uli
Re: CRC Stream
Gepostet: 12.01.2011 - 09:45 Uhr  ·  #3
The first byte in a pascal string is the length of the string, not the first character of the string.
