Application is reseting
Small change in program - strange output
Jest
Gepostet: 08.12.2010 - 17:43 Uhr  ·  #1
Hello,
working on 256A3 with 32MHz internal clock. Project information said, that only 19% of flash is used and 64% of RAM is free. Nothing special:
program DSC;
{$DEFINE DSC}
{ $WG}                                           //global Warnings off
Device = xmega256A3, VCC=3.3;
{ $BOOTRST $20000}                               //Reset Jump to $20000
Import SysTick, RTclock, TINAstack, ADC_A, TickTimer, TickTimer2,
       SLIPportC0, SPI_D, SLIPportE0, SLIPportE1, SerPortF0;
From System Import longWord, FlashCheck_S;
From SerPort Import SerPortSelect;
  OSCtype        = int32MHz,                     //CPU=32MHz
                   PLLmul=4,
                   prescB=1,                     //PeripherX4=32MHz
                   prescC=1;                     //PeripherX2=32MHz
  SysTick        = 10, adj;                      //msec
  RTClock        = iData, DateTime;              //Time, DateTime
  RTCsource      = SysTick;
  TINAdriver     = ENC424J600;                   // Ethernet
  TINAport       = SPI_C, PortC, 4;              // SPItyp, SS_Port, SS_Pin
  TINAtimer      = Timer_D0;
  TINAsockets    = 4;
  ADCrefA        = REF100;                       // intern 1.0V reference
  ADCprescA      = 256;                          // prescaler 256
  ADCchansA      = [ 0, 1, 2];
  TickTimer      = Timer_C0;                     // use Timer_C0 and no PortPin
  TickTimer2     = Timer_C1;                     // use Timer_C1 and no PortPin
  SLIPportC0     = 115200;                       // LCD
  SLIPportCtrlC0 = PortC, 0, positive;
  SPIorderD      = MSB;                          //FRAM
  SPImodeD       = 0;                            //Clock Phase and Polarity
  SPIprescD      = 1;                            //presc = 0..3 -> 4/16/64/128
  SPI_SSD        = PortD, 4;                     //bit for SS chipselect
  SLIPportE0     = 115200;
  SLIPportCtrlE0 = SingleWire;                   //no line driver involved
  SLIPportE1     = 115200;
  SLIPportCtrlE1 = SingleWire;                   //no line driver involved
  SerPortF0      = 115200, parEven;
  TxBufferF0     = 255, iData;
  RxBufferF0     = 8, iData;
  FlashChkSum    = ProgEnd;
Uses
  System, DSC_Globals_V70, FRAM, TINA, tnDHCP, LCD, Ethernet,
  xSC_Engine, xSC_SW_SLIP, Monitor, DSC_Monitor;
But, I came to the point, that adding a line in program results in numerous application resets at the beginning and also while working, it is reseting without reason - from my side of view. :-(
And, adding line or two, system is again working - and sometimes not.
So, I am really confused and lost in space. All units by them self are working. adding one by one it is OK till certain point, when system starts to reset and sometimes hangs. Strange...
Any help is top welcome... :-)
Best regards,
Andrej
Re: Application is reseting
Gepostet: 08.12.2010 - 18:14 Uhr  ·  #2
Hello Andrej,
did you try to increase stack and/or frame size?
Jest
Gepostet: 08.12.2010 - 22:54 Uhr  ·  #3
Hello Rolf,
yes, I increased those two numbers to $512 but still the same result.
Best regards,
Andrej
Gepostet: 09.12.2010 - 09:05 Uhr  ·  #4
Jest
Gepostet: 20.12.2010 - 16:08 Uhr  ·  #5
looks like, Avra was right - new board, another processor - no problems. :devil:
Tnx for support,
Andrej
