Writeln and my own procedure
Cusko
Gepostet: 13.07.2010 - 09:05 Uhr  ·  #1
Hello
Is it possible to use my own procedure in writeln() function?
E.g.
procedure EthOut;
writeln(EthOut, ' ');
Thanks
Re: Writeln and my own procedure
Gepostet: 13.07.2010 - 12:16 Uhr  ·  #2
Gepostet: 13.07.2010 - 12:17 Uhr  ·  #3
Hello Cusko,
if you write
{$DEVICE}
Procedure EthOut(b : byte);
then it should work.
Cusko
Gepostet: 14.07.2010 - 14:36 Uhr  ·  #4
Thank you for help,
I am interested in this because you can then simply change from SerOut to Ethernet in existing code.
But I find out from compiler manual that you can use only 8-bit variables in this case and sending one by one byte over ethernet is little to much.
Any other solution maybe?
Gepostet: 14.07.2010 - 17:27 Uhr  ·  #5
you can send it in loop by using your device procedure.
Gepostet: 14.07.2010 - 18:08 Uhr  ·  #6
You can cache EthOut() data in some array until CR or some special character arrives, and only then send whole array via ethernet.
Gepostet: 14.07.2010 - 18:10 Uhr  ·  #7
Hi Cusko.
When you are developing your own drivers you can do pretty well what you like. So just because WriteLn (and indeed Write) call your routine character by character, that doesn't mean that you have to send them by ethernet that way. You could, for example, store them to a buffer and only send via ethernet after a certain number of characters have been received or after a time out. This is transparent to any procedures outside your driver procedures. (Obviously you would need to test for timeout on a regular basis).
Hope this helps.
Merlin.
Cusko
Gepostet: 15.07.2010 - 13:35 Uhr  ·  #8
Thanks for suggestions
I will try to save into buffer.
I already tried similar thing but obviously wrong way.
My code was
{$DEVICE}
procedure EthOut( Letter:char);
  writeln(Serout, 'EthOut');
  TelnetTXBuffer:= TelnetTXBuffer+Letter;
  if Letter = #10 then
     TinaSendPacket(sTelnet, @TelnetTXBuffer, Word( Length( TelnetTXBuffer)));
     SetLength( TelnetTXBuffer, 0);
TelnetTXBuffer : string[100]
but if I work with TelnetTXBuffer in device procedure, the procedure will be started from writeln only once and not for every byte (I tested this). If I use only
TinaSendPacket(sTelnet,@Letter, 1);, procedure EthOut is callled for all bytes.
So I will try to build whole string with array.
