HMC6343 Kompass Modul
Alternativ Code gesucht
ERICH KATH
Herkunft: 61206 Wöllstadt
Homepage: ct-gmbh.de
Gepostet: 10.06.2010 - 07:00 Uhr  ·  #1
ich versuche gerade ein Kompass Modul zu integrieren. Hat das jemand schon erfolgreich getan? Suche alternativ Code hierzu:
adr : byte = $19;
i2cout(adr, $50);
mdelay(25);
i2cinp(adr, HeadMSB);
i2cinp(adr, HeadLSB);
i2cinp(adr, PitchMSB);
i2cinp(adr, PitchLSB);
i2cinp(adr, RollMSB);
i2cinp(adr, RollLSB);
HMSBHEX := byteToHex(HeadMSB);
HEADHEX := HMSBHEX + byteToHex(HeadLSB);
Headint := hextoint(HEADHEX);
Hfloat := float (Headint) / 10; // Heading
PMSBHEX := byteToHex(PitchMSB);
PitchHEX := PMSBHEX + byteToHex(PitchLSB);
Pitchint := hextoint(PitchHEX);
Pfloat := float(Pitchint) / 10; // Pitch
RMSBHEX := byteToHex(RollMSB);
RollHEX := RMSBHEX + byteToHex(RollLSB);
Rollint := hextoint(RollHEX);
Rfloat := Float(Rollint) / 10; // Roll
Das geht zwar, aber das Heading ist falsch.
Ich scheitere wohl da dran: "After each 8-bit transfer, the master device generates a 9 th clock pulse, and releases the SDA line".
    Nathan Seidle
    nathan@sparkfun.com
    Copyright Spark Fun Electronics© 2008
    Software I2C control
    PIC 16F88
    Reading and writing to HMC6343
    This is a internally tilt compensated compass.
#define Clock_8MHz
#define Baud_9600
#include "c:GlobalCodeC16F88.h"  // device dependent interrupt definitions
#pragma origin 4
#define STATUS_LED PORTB.3
#define SCL     PORTA.1
#define SDA     PORTA.0
#define WRITE_sda() TRISA = TRISA & 0b.1111.1110 //SDA must be output when writing
#define READ_sda()  TRISA = TRISA | 0b.0000.0001 //SDA must be input when reading - don't forget the resistor on SDA!!
#define I2C_DELAY   10
#define ACK     1
#define NO_ACK  0
#define DEVICE_WRITE    0x32 //Default HMC6343 I2C address - write
#define DEVICE_READ     0x33 //Default HMC6343 I2C address - read
void boot_up(void);
void send_command(uns8 command_byte);
uns8 read_eeprom(uns8 register_name);
void write_register(uns8 register_name, uns8 register_value);
void i2c_ack_polling(uns8 device_address);
void i2c_start(void);
void i2c_stop(void);
uns8 i2c_read_byte(void); //No ACK
uns8 i2c_read_bytes(void); //9th bit ACK
bit i2c_send_byte(uns8 out_byte);
void delay_ms(uns16 x);
void delay_us(uns16 x);
uns8 bin2Hex(char x);
void printf(const char *nate, int16 my_byte);
uns8 hmc_data[6];
void main(void)
    uns8 choice;
    boot_up(); //Init ports and settings
    STATUS_LED = 0;
    printf("nHMC6343 Testing:nnr", 0);
    delay_ms(100);
    uns8 response;
    response = read_eeprom(0x00); //Who am I
    printf("nrWho am I (should be 0x32): %hnr", response);
    while(1)
        STATUS_LED ^= 1;
        /*if(RCIF)
            choice = RCREG;
            if(choice == 'x') break;
        send_command(0x50); //Post heading data to hmc_data array
        printf("head=%d ", hmc_data[0]);
        printf("%d ", hmc_data[1]);
        printf("pitch=%d ", hmc_data[2]);
        printf("%d ", hmc_data[3]);
        printf("roll=%d ", hmc_data[4]);
        printf("%d ", hmc_data[5]);
        printf("n", 0);
        delay_ms(200);
    while(1);
}//End Main
void boot_up(void)
    //Setup Ports
    ANSEL = 0b.0000.0000; //Turn off A/D
    PORTA = 0b.0000.0000;
    TRISA = 0b.0000.0000;  //0 = Output, 1 = Input
    //Output PB7, PB6, PB4 - Input PB1
    PORTB = 0b.1100.0000;
    TRISB = 0b.0000.0110;   //0 = Output, 1 = Input RX on RB2
    //OPREG = 0b.1111.1111; //Enable pull-ups
    //Setup the hardware UART module
    SPBRG = 51; //8MHz for 9600 inital communication baud rate
    //SPBRG = 129; //20MHz for 9600 inital communication baud rate
    TXSTA = 0b.0010.0100; //8-bit asych mode, high speed uart enabled
    RCSTA = 0b.1001.0000; //Serial port enable, 8-bit asych continous receive mode
//Gets bulk data for the four different post types (Accel, Mag, Heading, Tilt)
    uns8 in_byte, i;
    i2c_ack_polling(DEVICE_WRITE);
    i2c_start();
    i2c_send_byte(DEVICE_WRITE);
    i2c_send_byte(command_byte); //Send command
    //i2c_stop();
    i2c_start(); //Repeat start (SR)
    i2c_send_byte(DEVICE_READ); //Now ask the IC to report on the last command
    for(i = 0 ; i < 6 ; i++)
        in_byte = i2c_read_bytes();
        hmc_data[i] = in_byte; //Read in 6 data bytes
    i2c_stop();
    i2c_stop();
//Reads a register
    uns8 in_byte;
    i2c_start();
    i2c_send_byte(0xE1); //Read from EEPROM
    i2c_send_byte(register_name); //Write register address
    //i2c_stop();
    in_byte = i2c_read_byte();
    i2c_stop();
    return(in_byte);
//Write to a register
    i2c_start();
    i2c_send_byte(register_value); //Write data
    i2c_stop();
    //Return nothing
//Software I2C Routines
    while(1)
        i2c_start();
        if (i2c_send_byte(device_address) == ACK) break;
    i2c_stop();
    WRITE_sda();
    SDA = 1;
    delay_us(I2C_DELAY);
    SCL = 1;
    SDA = 0;
//The I2C Clock has a minimum of 2us high time and 2us low time
void i2c_stop(void)
    SCL = 0;
    WRITE_sda();
    SDA = 0;
    SCL = 1;
    SDA = 1;
//8MHz = 0.5us per instruction
    int j, in_byte;
    SCL = 0;
    READ_sda();
    for(j = 0 ; j < 8 ; j++)
        SCL = 0;
        SCL = 1;
        in_byte = rl(in_byte);
        in_byte.0 = SDA;
    //Send 9th bit acknowledge
    For single byte reads, there is NMAK or no master acknowledge
    SCL = 0;
    WRITE_sda();
    SDA = 0;
    SCL = 1;
    SCL = 0;
    SDA = 1;
    while(1);
    return(in_byte);
    int j, in_byte;
    SCL = 0;
    READ_sda();
        SCL = 0;
        SCL = 1;
        in_byte.0 = SDA;
    SCL = 0;
    WRITE_sda();
    SDA = 0;
    SCL = 1;
    SCL = 0;
    SDA = 1;
    return(in_byte);
//8MHz = 500ns per instruction
    uns8 i;
    WRITE_sda();
    for(i = 0 ; i < 8 ; i++)
        SCL = 0;
        out_byte = rl(out_byte);
        SDA = Carry;
        delay_us(5);
        SCL = 1;
    //Read ack
    SCL = 0;
    READ_sda();
    SCL = 1;
    //Wait for IC to acknowledge
    for(i = 0 ; i < 255 ; i++)
        if(SDA == 0) break;
    SCL = 0;
    if (i == 255) return(NO_ACK);
    return(ACK);
//General short delay
    //Clocks out at 1006us per 1ms
    uns8 y, z;
    for ( ; x > 0 ; x--)
        for ( y = 0 ; y < 4 ; y++)
            for ( z = 0 ; z < 69 ; z++);
//Really short delay
    //Calling with 1us returns 7.5us
    //Calling with 10us returns 48
    //Calling with 1000us returns 4.5ms
    while(--x);
//Sends nate to the Transmit Register
void putc(uns8 nate)
    while(TXIF == 0);
    TXREG = nate;
uns8 getc(void)
    while(RCIF == 0);
    return (RCREG);
uns8 scanc(void)
    uns16 counter = 0;
    //CREN = 0;
    //CREN = 1;
    RCIF = 0;
    while(RCIF == 0)
        counter++;
        if(counter == 1000) return 0;
    return (RCREG);
//Returns ASCII Decimal and Hex values
   skip(x);
   #pragma return[16] = "0123456789ABCDEF"
//Prints a string including variables
    uns8 i, k, m, temp;
    uns8 high_byte = 0, low_byte = 0;
    uns8 y, z;
    uns8 decimal_output[5];
    for(i = 0 ; ; i++)
        k = nate[i];
        if (k == '')
            break;
        else if (k == '%') //Print var
            i++;
            k = nate[i];
            if (k == '')
                break;
            else if (k == '') //Print special characters
                i++;
                k = nate[i];
                putc(k);
            } //End Special Characters
            else if (k == 'b') //Print Binary
                for( m = 0 ; m < 8 ; m++ )
                    if (my_byte.7 == 1) putc('1');
                    if (my_byte.7 == 0) putc('0');
                    if (m == 3) putc(' ');
                    my_byte = my_byte << 1;
            } //End Binary
            else if (k == 'd') //Print Decimal
                //Print negative sign and take 2's compliment
                if(my_byte < 0)
                    putc('-');
                    my_byte *= -1;
                if (my_byte == 0)
                    putc('0');
                    //Divide number by a series of 10s
                    for(m = 4 ; my_byte > 0 ; m--)
                        temp = my_byte % (uns16)10;
                        decimal_output[m] = temp;
                        my_byte = my_byte / (uns16)10;
                    for(m++ ; m < 5 ; m++)
                        putc(bin2Hex(decimal_output[m]));
            } //End Decimal
            else if (k == 'h') //Print Hex
                //New trick 3-15-04
                putc('0');
                putc('x');
                if(my_byte > 0x00FF)
                    putc(bin2Hex(my_byte.high8 >> 4));
                    putc(bin2Hex(my_byte.high8 & 0b.0000.1111));
                putc(bin2Hex(my_byte.low8 >> 4));
                putc(bin2Hex(my_byte.low8 & 0b.0000.1111));
                /*high_byte.3 = my_byte.7;
                high_byte.2 = my_byte.6;
                high_byte.1 = my_byte.5;
                high_byte.0 = my_byte.4;
                low_byte.3 = my_byte.3;
                low_byte.2 = my_byte.2;
                low_byte.1 = my_byte.1;
                low_byte.0 = my_byte.0;
                putc('0');
                putc('x');
                putc(bin2Hex(high_byte));
                putc(bin2Hex(low_byte));*/
            } //End Hex
            else if (k == 'f') //Print Float
                putc('!');
            } //End Float
            else if (k == 'u') //Print Direct Character
                //All ascii characters below 20 are special and screwy characters
                //if(my_byte > 20)
                    putc(my_byte);
            } //End Direct
        } //End Special Chars
            putc(k);
Leider kann ich kein C nach Pascal ändern...
ERICH KATH
