Anbei eine Anpassung und Demo für einen UC1698 Grafik-LCD-Controller.
program XMEGA_UC1698;
// XMEGA und LCD-Grafik-Display 256 x 64 Punkte
// RGB Grafik-Controller UC1698 über SPI an XMEGA
// DEMO 7 Schnittstellencode für E-LAB / AVRco
// User frei zu verwenden.
// info(at)pvs-deck.de
// Stand: 06.02.2018
{ $WG} {global Warnings off}
Device = xmega256A3U, VCC = 3.3;
//Device = xmega128A1U, VCC = 3.3;
NoteBook = D;
COMport = USB;
LockBits0 = [];
FuseBits0 = [];
FuseBits1 = [ WDPER0, WDPER3 ]; // Watchdog 0:3 / 0110 512CLK 0.512s
// 0=WDPER0
// 1=WDPER1
// 2=WDPER2
// 3=WDPER3
FuseBits2 = []; // mandatory !!
// Brown-out is obligatory with USB !!!
// FuseBits5 = [BODACT0, BodLevel0, BodLevel1, BodLevel2];
FuseBits5 = [BodLevel0,BodLevel2, BodAct0]; // 2.6V:
ProgFlash = true; // or false – program Flash
ProgEEprom= FALSE; // or false – program EEprom
AutoRelease = true; // or false – Release Target // Wichtig für Programmierung über UPP !!
Import SysTick, SerPortD1, LCDGraphic, SPI_E;
//From System Import CharSet;
from LCDGraphic import CharSet; {block CharSet, pixels}
// XMega USB must use the internal 32MHz OSC. So the system must use the 2MHz OSC
// OSCtype = int2MHz, PLLmul = 16, prescB = 1, prescC = 1;
OSCtype = int2MHz, PLLmul = 8, prescB = 1, prescC = 1;
//OSCtype = int32MHz, PLLmul=5, prescB=1, prescC=1, overdrive; // 40MHz
// OSCtype = int32MHz, PLLmul=6, prescB=1, prescC=1, overdrive; // 48MHz
//OSCtype = int32MHz, PLLmul=7, prescB=1, prescC=1, overdrive; // 56MHz
//OSCtype = int32MHz, PLLmul=8, prescB=1, prescC=1, overdrive; //64MHz
SysTick = 10; // msec
StackSize = $0512, iData;
FrameSize = $0512, iData;
// SerPort D1
SerPortD1 = 19200, Databit8,parNone, Stop1; {9600 Baud, 1Stopbit}
RxBufferD1 = 100, iData;
TxBufferD1 = 100, iData;
// LCD-Display-Daten
LCDGraphic = 256,64, 8; { x-pix, y-pix, accesswidth }
LCDgraphMode = readonly, iData;
// LCDgraphMode = column, iData;
DefCharSet = 'Graphchars.pchr';
GViewports = 1, iData; { logical ViewPorts, scalings }
TGraphStr = 24;
// SPI_E
SPIorderE = MSB;
SPImodeE = 0; // Clock Phase and Polarity
SPIprescE = 0; // presc = 0..3 -> 4/16/64/128. Double speed optional
SPI_SSE = PortE, 4; // use this pin as SS chipselect
{ Type Declarations }
{ Const Declarations }
// definitions for bitmap types
CONST
elabbmp : Array[1..(32*32 div 8)+2] of Byte = 'e-lab.pbmp';
{ Var Declarations }
SerTimer : SysTimer;
WDITimer : SysTimer;
bTast0, bTast1,bTast2,bTast3 : boolean;
// IO Onboard
HxIN_TAST0 [@PINA, 2 ] : bit;
HxIN_TAST1 [@PINA, 1 ] : bit;
HxIN_TAST2 [@PINA, 3 ] : bit;
HxIN_TAST3 [@PINA, 4 ] : bit;
HxDispData [@PORTE, 2 ] : bit;
// LCD VARs
bContrast_level : byte;
{ functions }
// Debug / Infoausgabe an Ser-Port
procedure DebugOut( OutStr : String[59] );
Writeln(SerOutD1,OutStr);
end; //Ende Debug Out
// Daten an LCD/SPI schreiben BYTE
// bei DATA true, Daten-PIN an LCD-Controller setzen
Procedure WriteLCD(bData: Byte; DispData: Boolean);
If DispData
then
HxDispData:=TRUE; // Daten
HxDispData:=FALSE; // CMD
SPIOutByteE(bData); // Daten über SPI senden
End WriteLCD;
// Daten an LCD/SPI schreiben WORD
Procedure wWriteLCD(wData: WORD; DispData: Boolean);
If DispData
then
SPIOutWordE(wData); // Daten über SPI senden
End wWriteLCD;
// LCD mit Schwarz füllen / Clear-Black
Procedure display_black;
ii : integer;
ij : integer;
for ii:= 0 to 63 do // Zeilen
for ij:= 0 to 128 do //1byte data or 2 dot 120*2=240dot
WriteLCD( $FF, true );
endfor;
endfor;
end display_black;
// LCD mit Weiss füllen / Clear-White
procedure display_white;
ii : integer;
ij : integer;
WriteLCD( $00, true );
endfor;
endfor;
end display_white;
// Setze auf Spalte / Reihe
procedure display_address( DispSpalte : byte; DispZeile : Byte);
LSB : BYTE;
MSB : BYTE;
// Spalte/Col=0 to 263 Zeile/Row=0 to 63
// Displayspalte / Column address LSB
LSB:= DispSpalte AND $0F;
WriteLCD( $00 OR LSB, false );
// Displayspalte / Column address MSB
MSB:= (DispSpalte AND $F0) SHR 4;
WriteLCD( $10 OR MSB, false );
// Displayzeile / Row address LSB
LSB:= DispZeile AND $0F;
WriteLCD( $60 OR LSB, false );
// Displayzeile / Row address MSB
MSB:= (DispZeile AND $F0) SHR 4;
WriteLCD( $70 OR MSB, false );
end display_address;
// turns 1byte B/W data to Displayformat
procedure DispBW2RGB( temp : byte);
temp1,temp2,temp3,temp4,temp5,temp6,temp7,temp8 : byte;
h11,h12,h13,h14,h15,h16,h17,h18,d1,d2,d3,d4 : byte;
temp1:=temp AND $80;
temp2:=( temp AND $40) SHR 3; // >>3;
temp3:=( temp AND $20) SHL 2; // <<2;
temp4:=( temp AND $10) SHR 1; // >>1;
temp5:=( temp AND $08) SHL 4; // <<4;
temp6:=( temp AND $04) SHL 1; // <<1;
temp7:=( temp AND $02) SHL 6; // <<6;
temp8:=( temp AND $01) SHL 3; // <<3;
h11:=temp1 OR (temp1 SHR 1) OR (temp1 SHR 2) OR (temp1 SHR 3);
h12:=temp2 OR (temp2 SHR 1) OR (temp2 SHR 2) OR (temp2 SHR 3);
h13:=temp3 OR (temp3 SHR 1) OR (temp3 SHR 2) OR (temp3 SHR 3);
h14:=temp4 OR (temp4 SHR 1) OR (temp4 SHR 2) OR (temp4 SHR 3);
h15:=temp5 OR (temp5 SHR 1) OR (temp5 SHR 2) OR (temp5 SHR 3);
h16:=temp6 OR (temp6 SHR 1) OR (temp6 SHR 2) OR (temp6 SHR 3);
h17:=temp7 OR (temp7 SHR 1) OR (temp7 SHR 2) OR (temp7 SHR 3);
h18:=temp8 OR (temp8 SHR 1) OR (temp8 SHR 2) OR (temp8 SHR 3);
d1:= h11 OR h12; d2:= h13 OR h14;
d3:= h15 OR h16; d4:= h17 OR h18;
// Schreibe aufbereitete Daten an Display
WriteLCD(d1,true); WriteLCD(d2,true);
WriteLCD(d3,true); WriteLCD(d4,true);
end DispBW2RGB;
// Befehl Funktion für Software Reset Controller
// ACHTUNG Display-RAM wird nicht gelöscht, aber
// der Controller wird auf Grundeinstellungen gesetzt.
procedure LCDReset;
WriteLCD( $E2, false);
end LCDReset;
// Display-Init
Procedure LCDInit;
MDelay(200);
LCDReset;
MDelay(100);
//*power control*/
WriteLCD($e9,false); //Bias Ratio:1/10 bias
WriteLCD($2b,false); //power control set as internal power
WriteLCD($24,false); //set temperate compensation as 0%
WriteLCD($81,false); //electronic potentionmeter
bContrast_level:= 0;
WriteLCD(bContrast_level,false);
//*display control*/
WriteLCD($a4,false); //all pixel off
WriteLCD($a6,false); //inverse display off
//*lcd control*/
WriteLCD($c4,false); //Set LCD Maping Control (MY=1, MX=0)
WriteLCD($a1,false); //line rate
WriteLCD($d1,false); //rgb-rgb
WriteLCD($d5,false); //4k color mode
WriteLCD($84,false); //12:partial display control disable
//*n-line inversion*/
WriteLCD($c8,false);
WriteLCD($10,false); //enable NIV
//*com scan fuction*/
WriteLCD($da,false); //enable FRC,PWM,LRM sequence
//*window*/
WriteLCD($f4,false); //wpc0:column
WriteLCD(0,false); //start from 0
WriteLCD($f6,false); //wpc1
WriteLCD(85,false); //end:3*86=258
WriteLCD($f5,false); //wpp0:row
WriteLCD($00,false); //start from 0
WriteLCD($f7,false); //wpp1
WriteLCD(63,false); //end 128
WriteLCD($f8,false); //inside mode
WriteLCD($89,false); //RAM control
//*scroll line*/
WriteLCD($40,false); //low bit of scroll line
WriteLCD($50,false); //high bit of scroll line
WriteLCD($90,false); //14:FLT,FLB set
//*partial display*/
WriteLCD($85,false); //12,set partial display control:on
WriteLCD($f1,false); //com end
WriteLCD(63,false); //64
WriteLCD($f2,false); //display start
WriteLCD(0,false); //0
WriteLCD($f3,false); //display end
display_address(0,0);
display_white;
WriteLCD($ad,false); //display on,select on/off mode.Green Enhance mode disable
MDelay(200);
End LCDInit;
// GraphIOS
// Anpassung an das AVRco GraphSystem
UserDevice GraphIOS (cmd : byte; data : byte);
// commands passed to user defined function "GraphIOS"
// cmd 0 set row address data = row
// cmd 1 write data byte data = content
if cmd = 0 then
display_address( 0, data); // set row addr = data
DispBW2RGB( data ); // Bereite Daten auf und schreibe Daten an LCD
end GraphIOS;
// INIT Werte IOs
procedure InitPorts;
// PIN0CTRLA := %01011000; // pullup und INVERT
PIN2CTRLA := %01011000; // pullup und INVERT
DDRA.2:= 0; // 0=EINGANG 1=Ausgang
// PIN1CTRLA := %01011000; // pullup und INVERT
DDRA.1:= 0; // 0=EINGANG 1=Ausgang
PIN3CTRLA := %01011000; // pullup und INVERT
DDRA.3:= 0; // 0=EINGANG 1=Ausgang
PIN4CTRLA := %01011000; // pullup und INVERT
DDRA.4:= 0; // 0=EINGANG 1=Ausgang
//HxDispData
DDRE.2:= 1; // 0=EINGANG 1=Ausgang
end InitPorts;
// Demoausgabe an das Display
Procedure Start;
gSetTextJustify(alHorLeft, alVertTop);
gSetTextMode(wmSetPix);
gSetTextBkGnd(bkTransp);
gSetCharSetRam(false);
gSetLineMode(wmXorPix);
gDrawRect(0,0,254,63,$FF);
gDrawString(3,3,2,2,TxtRot0,'0123456789');
gDrawString(2,21,3,3,TxtRot0,'C');
gDrawString(8,35,3,3,TxtRot0,'H');
gDrawString(180,50,1,1,TxtRot0,'256x64 Pixel');
gDrawString(45,27,1,1,TxtRot0,'Contr:UC1698');
gDrawString(170,32,1,1,TxtRot0,'Rot0');
gDrawString(170,32,1,1,TxtRot90,'Rot90');
gDrawString(170,25,1,1,TxtRot180,'Rot180');
gDrawString(170,25,1,1,TxtRot270,'Rot270');
gDrawBitMap(212,2,@ELABbmp,wmSetPix);
gFillRect(35,45,100,60,$FF);
gDrawRect(55,40,120,55,$FF);
gDrawCircle(140,38,13,$FF);
gFillCircle(135,50,10,$FF);
gSetTextBkGnd(bkNormal);
gDispRefresh;
End Start;
{ Main Program }
InitPorts;
EnableInts($87);
LCDInit;
MDelay(100);
Start;
DebugOut( 'System gestartet....');
// Taste 0
if (HxIN_TAST0 AND not bTast0)then
DebugOut('Taste 0: LCDInit;');
bTast0:= true;
LCDInit;
if (not HxIN_TAST0 AND bTast0)then
bTast0:= false;
// Taste 1
if (HxIN_TAST1 AND not bTast1)then
DebugOut('Taste 1: Start;');
bTast1:= true;
Start;
if (not HxIN_TAST1 AND bTast1)then
bTast1:= false;
// Taste 2
if (HxIN_TAST2 AND not bTast2)then
// DebugOut('Taste 2: gDrawLine');
bTast2:= true;
display_white;
if (not HxIN_TAST2 AND bTast2)then
bTast2:= false;
// Taste 3
if (HxIN_TAST3 AND not bTast3)then
DebugOut('Taste 3: ');
bTast3:= true;
LCDReset;
if (not HxIN_TAST3 AND bTast3)then
bTast3:= false;
end XMEGA_UC1698.
NoteBook = D;
COMport = USB;
LockBits0 = [];
FuseBits0 = [];
// 0=WDPER0
// 1=WDPER1
// 2=WDPER2
// 3=WDPER3
// SerPort D1
TGraphStr = 24;
// SPI_E
SPIorderE = MSB;
CONST
// IO Onboard
// LCD VARs
{ functions }
If DispData
then
End WriteLCD;
If DispData
then
End wWriteLCD;
ii : integer;
ij : integer;
endfor;
endfor;
end display_black;
ii : integer;
ij : integer;
endfor;
endfor;
end display_white;
LSB : BYTE;
MSB : BYTE;
end DispBW2RGB;
procedure LCDReset;
end LCDReset;
// Display-Init
Procedure LCDInit;
MDelay(200);
LCDReset;
MDelay(100);
//*power control*/
//*lcd control*/
//*window*/
//*scroll line*/
display_white;
MDelay(200);
End LCDInit;
// GraphIOS
if cmd = 0 then
end GraphIOS;
// INIT Werte IOs
//HxDispData
end InitPorts;
Procedure Start;
gDispRefresh;
End Start;
{ Main Program }
InitPorts;
EnableInts($87);
LCDInit;
MDelay(100);
Start;
// Taste 0
bTast0:= true;
LCDInit;
bTast0:= false;
// Taste 1
bTast1:= true;
Start;
bTast1:= false;
// Taste 2
bTast2:= true;
display_white;
bTast2:= false;
// Taste 3
bTast3:= true;
LCDReset;
bTast3:= false;
end XMEGA_UC1698.
| Dateiname: | XMEGA_UC1698.zip |
| Dateigröße: | 146.3 KB |
| Titel: | XMEGA_UC1698 AVRco Code |
| Information: | XMEGA_UC1698 AVRco Code |
| Heruntergeladen: | 11 |
| Dateiname: | XMEGA_UC1698_Bild.jpg |
| Dateigröße: | 1.72 MB |
| Titel: | XMEGA_UC1698_Bild |
| Information: | XMEGA_UC1698_Bild |
| Heruntergeladen: | 111 |
