alias problem
Re: alias problem
Gepostet: 24.06.2014 - 00:43 Uhr  ·  #9
Zitat geschrieben von rh
some things are easy to implement, like this one.
Others are not, like passing bits to a function.
Fully understandable. We can't win them all...
Re: alias problem
Gepostet: 09.03.2015 - 20:54 Uhr  ·  #10
WaitPipe is a very special construction and was not intended to be
used with ALIAS. But now it is supported.
I have tested and... IT COMPILES, IT COMPILES IT COMPILES !!! :D
=D> :-({|= =D> :occasion7: 👋
Now I can share communication unit between different projects without tons of ugly IFDEFs covering all possible AVR serial ports combination in code.
🆒 :juggle:
THANK YOU ROLF!
:cheers: :occasion5: 👍
Unfortunately it does not work any more. The same line like WaitPipe(AliasToRxBuffer2) does not compile with AvrCo 5.0.4.90 so my code is broken now. As a workaround I have found it to work with slightly older custom AvrCo.exe dated 23.06.2014 from your mail. Could you please fix it?
Re: alias problem
Gepostet: 09.03.2015 - 22:52 Uhr  ·  #11
Hello Avra,
Alias is not an operator. It is handled similar as a define, type etc.
I tested your small application you posted here last year and it worked.
Re: alias problem
Gepostet: 12.03.2015 - 00:12 Uhr  ·  #12
I still have 5.04.90 which doesn't compile and custom 5.04.73+ dated 23.06.2014 from your mail which compiles well, so that was the root of my confusion. After renewing license today I could test with latest 5.04.98 and it compiles again without problems.
Please forgive me for false alarm. :buhu: :dontknow: :buhu:
Re: alias problem
Gepostet: 12.03.2015 - 15:08 Uhr  ·  #13
Hello Avra,
I'm glad to hear this.
But what about your last problem with empty packets receptions?
Re: alias problem
Gepostet: 16.03.2015 - 12:31 Uhr  ·  #14
Details are in your mailbox.
