Probleme mit Fix64
  • Seite 3 von 5
Re: Probleme mit Fix64
Gepostet: 17.04.2013 - 17:36 Uhr  ·  #17
Hi Rolf, hello Avra,
using Fix64 quite a while now, I found the following problem: The Source for "FloatToFix64" above and the build in function in the compiler give erratic results when working with very small negative values:
The code
Var
lFl1 : Float;
lFl1 := -0.00000000001;
SLIP_WriteStr('TXT|lFl1: '+FloatToStr(lFl1));
SLIP_WriteStr('TXT|FloatToFix64(lFl1): '+Fix64ToStr(FloatToFix64(lFl1)) );
End;
Will give the following result:
lFl1: -9.999992E-12
FloatToFix64(lFl1): -1.000000000
The FloatToFix64 conversion gives -1 !! I checked, it is not the Fix64ToStr Function. So, all calculation with very small negative Values, that are converted from FloatToFix64 go wrong.
Can you have a look? If you fix the issue, I would be glad, if you could post the corrected code for FloatToFix64 here, so I can prevent the "uses uFix64" clause (making my code too big)
Hope you can help!
Thanks, Michael
Gepostet: 17.04.2013 - 21:56 Uhr  ·  #18
Hello Michael,
I'm afraid I can't help you there.
I think Avra is the right one for this.
Gepostet: 18.04.2013 - 05:35 Uhr  ·  #19
Hi Rolf,
Yes, I think you are right. I did some testing and now I have changed the Function a little bit to prevent the false -1 results. However, Avra should have a look, because the internal AVRco routine in uFix64 gives the erratic results too..
Cheers, Michael
function FloatToFix64(const a: float): fix64;
Tmp: TFix64Overlay;
If (a > -0.0000000009) And (a < 0) Then
a := 0;
Tmp.i := Trunc(a);
if (a < 0) and (Frac(a) <> 0) then
Dec(Tmp.i);
Tmp.f := Trunc(Frac(a) * (float($FFFFFFFF) + 1));
return(Tmp.fix);
Gepostet: 18.04.2013 - 07:48 Uhr  ·  #20
I will take a look.
Gepostet: 18.04.2013 - 13:14 Uhr  ·  #21
Hello Avra,
here a code snippet which shows the problem:
  f                    : float;
  f64                  : fix64;
  TFix64Overlay = record
                    fix : fix64;
                    i [@fix+4]: longint;
                    f [@fix] : longword;
  Tmp: TFix64Overlay;
  Tmp.i := Trunc(a);
    Dec(Tmp.i);
  return(Tmp.fix);
procedure FixTest;
  f:= -0.00000000001;
  f64:= FloatToFix64(f);
Gepostet: 20.04.2013 - 17:22 Uhr  ·  #22
Hello Michael,
because the smallest number in Fix64 can be +/-0.000000001 your entry of -0.00000000001
exceeds the possible Fix64 range. The FloatToFix64 function doesn't recpgnize this.
But you can change this by an additional check in this function.
Maybe Avra has a more elegant way for this...
  Tmp: TFix64Overlay;
  if a = 0.0 then
    return(0.0);
  elsif abs(a) < 0.000000001 then
    if sign(a) then
      return(0.000000001);
      return(-0.000000001);
  Tmp.i := Trunc(a);
    Dec(Tmp.i);
  return(Tmp.fix);
Gepostet: 21.04.2013 - 00:32 Uhr  ·  #23
Hello Rolf,
Your solution is in the right direction, but it has a slight error if a=0. This should be the real fix:
  Tmp: TFix64Overlay;
  if ValueInRange(a, -2.328307E-10, 0) then
    Tmp.fix := 0;
    Tmp.i := Trunc(a);
      Dec(Tmp.i);
  return(Tmp.fix);
I will send you the corrected unit once I return to my hometown.
Michael, Thank you for noticing this bug!
Gepostet: 21.04.2013 - 00:37 Uhr  ·  #24
Hello Avra,
thank you. But I'm missing the positive overflow.
And a zro return can be very dangerous. It should be the smallest Fix64 number
so that, for example, a later division by zero can not happen.
  • Seite 3 von 5
