How does GetTimeCounterP work?
nwrightson
Herkunft: Newcastle
Homepage: nweha.homeserver.c…
Gepostet: 21.04.2012 - 09:19 Uhr  ·  #1
In another thread, I'm trying to decode a X10 Rf signal, basically a serial protocol.
When I came across GetTimeCounterP, I thought my dreams had come true.
But... I'm having trouble making it work.
It would appear that GetTimeCounterP starts counting on a High to Low transition. So it gets the Loigc 0 period first and then the Logic 1 period.
How do I get GetTimeCounterP to start on a Positive ie Low to High transition?
So that it gets the Loigc 1 period first and then the Logic 0 period.
There are long levels of Logic 0 between messages. This is the Idle state.
And I don't want to have to add an inverter. The PCB already exists.
The format is -
Header = 9mS at Logic 1, then 4.5mS at Logic 0
A received 0 (Zero) bit is indicated by 0.55mS at Logic 1, then 0.55mS at Logic 0
A received 1 (One) bit is indicated by 0.55mS at Logic 1, then 1.6mS at Logic 0
My code looks something like
Device = mega8, VCC=5;
Import FreqCount;
  FreqTimer      = Timer1;
Var
  CntHigh,CntLow     : word;
  CntOverFlow : Boolean ;
   SetFreqCountMode(TPulseBase100ms);
Loop
    CntOverFlow:= GetTimeCounterP(CntHigh,CntLow);
    If (CntHigh > 800) AND (CntHigh < 1100) {AND (CntLow > 350) AND (CntLow < 500)} then  WriteLn(SerOut, 'HEADER='+IntToStr(CntHigh:6:2)+'ms '+IntToStr(CntLow:6:2)+'ms ');  Endif;
        If (CntHigh > 30) AND (CntHigh < 60) AND (CntLow > 30) AND (CntLow < 60) then ST:=ST+'0'; Endif;
        If (CntHigh > 30) AND (CntHigh < 60) AND (CntLow > 150) AND (CntLow < 170) then ST:=ST+'1'; Endif;
      if GetFreqCountOvrFlow <> 0 then
        WriteLn(SerOut, ST);
        St := '';
Neil.
Re: How does GetTimeCounterP work?
Gepostet: 21.04.2012 - 16:44 Uhr  ·  #2
Hi Neil.
Well I suppose the obvious answer is use
GetTimeCounterP( CntLow, CntHigh);
This effectively inverts the states.
Merlin.
nwrightson
Herkunft: Newcastle
Gepostet: 22.04.2012 - 05:22 Uhr  ·  #3
Hi Merlin
The issue is that it starts on a negative edge not a positive edge.
The manual/help file, seems to suggest that it reads the length of the Logic 1 period first and then the length og the Logic 0. But it also contradicts itself in the last statement, implying that it returns Count Total :(
From the help file
Function GetTimeCounterP (var Count1, Count2: word) : boolean;
Returns the counter values of the last pulse time measure cycle.
Count1: high, Count2: low. False at overflow.
From the manual
GetTimeCounterP, GetTimeCounterP2
The function GetTimeCounterP returns the result (16bit value) the plain counter content of the last pulse
time measure cycle. The values Count1 and Count2 contain the timer value counted in the “high“ and “low” time of the cycle. So for example it is possible to get the on/off relation of a PWM cycle. If an overflow
occurred a false is returned. The FreqCountMode must be set to PulseMode.
A call to this function also clears the semaphore.
Function GetTimeCounterP(var CountP, CountTot : word): boolean;
Neil
Gepostet: 22.04.2012 - 11:40 Uhr  ·  #4
Hi Neil.
Yes I see. I was thinking that because you are in a loop it doesn't matter, but of course the return to the function is not timely.
Sorry.
