ATmega64-16AU Serport2 Not work
Peter KWS
Gepostet: 29.11.2011 - 23:35 Uhr  ·  #1
Hallo all, pleas i need help with mein project with ATMEGA64. I need read and write data in Serport1 and Serport2.
I write basic testing program for reading and send data.
Serport1 work good (No problem) but Serport2 is absolutly 'death' :( .
I dont know why!
I triyng change the MCU for new and Serport2 still not work :(
Max232 on serport2 is ok and testing with serport1 and work good. Where is problem?
Any idea?
here is my basic code...
program test_serial;
{ $BOOTRST $07000} {Reset Jump to $07000}
{ $WG} {global Warnings off}
Device = mega64, VCC=5;
Import SysTick, SerPort, SerPort2;
From System Import ;
ProcClock = 16000000; {Hertz}
SysTick = 10; {msec}
StackSize = $0064, iData;
FrameSize = $0064, iData;
SerPort = 19200, Stop1; {Baud, StopBits|Parity}
RxBuffer = 16, iData;
TxBuffer = 16, iData;
SerPort2 = 19200, Stop1; {Baud, StopBits|Parity}
RxBuffer2 = 16, iData;
TxBuffer2 = 16, iData;
{ Type Declarations }
{ Const Declarations }
{ Var Declarations }
Led_TX [@PortD, 5] : Bit;
Led_RX [@PortD, 4] : Bit;
ZnakIn : Array [0..20] of byte;
InCykl : byte;
Led_Rxcount : Integer;
Led_Txcount : Integer;
{ functions }
interrupt RXRDY;
ZnakIn[InCykl] := SerInp;
if ZnakIn[0] = $31 then
InCykl := InCykl + 1;
InCykl := 0;
procedure InitPorts;
DDRD := %00110000;
end InitPorts;
{ Main Program }
InitPorts;
if InCykl >= 18 then
InCykl := 0;
ZnakIn[0] := 0;
Led_Rx := True;
Write( SerOut, 'Test Port 1' );
Write( SerOut2, 'Test Port 2' );
FlushBuffer ( TxBuffer );
FlushBuffer ( TxBuffer2 );
Led_Tx := True;
If (Led_rx = true) then Inc(Led_Rxcount); else Led_Rxcount := 0; endif;
If (Led_Rxcount >= 50) then Led_Rx := false; Led_Rxcount := 0; endif;
If (Led_tx = true) then Inc(Led_Txcount); else Led_Txcount := 0; endif;
If (Led_Txcount >= 50) then Led_Tx := false; Led_Txcount := 0; endif;
mdelay(1);
end test_serial.
Thanks for your time.
Re: ATmega64-16AU Serport2 Not work
Gepostet: 30.11.2011 - 00:10 Uhr  ·  #2
Hi Peter and welcome here!
You must disable (set to binary "1") the M103C fuse (Mega103 compatibility mode) to archieve the full control of the Mega64 functions. This fuse is active by factory default!
hth
Peter KWS
Gepostet: 30.11.2011 - 00:22 Uhr  ·  #3
Yess, Thank you very much Gunter, now is all ok :) SerPort2 work fine :) Good idea!! Bye :)
Gepostet: 30.11.2011 - 00:26 Uhr  ·  #4
Good idea!!
no problem. This is one of the 3 or 4 most famous problems:
besides enabled JTAG and different SPI programming pins on some Megas.
