Mega16 and LCD44780 connected to PORTC
not work
NickBahtin
Gepostet: 15.07.2011 - 18:10 Uhr  ·  #1
Hi? expert's! Connect the display according to the scheme Mega163sch, only with port C -
On port "A" works - at the port "C" will not work! Help me Please!
Re: Mega16 and LCD44780 connected to PORTC
Gepostet: 15.07.2011 - 18:30 Uhr  ·  #2
Hi Nick,
Port C uses some of its pins for JTAG signaling and you have
JTAG still enabled. So these pins are not available for general IO.
Disable the JTAGEN fuse (set to binary 1) or use "Disable_JTAGPORT".
NickBahtin
Gepostet: 18.07.2011 - 05:58 Uhr  ·  #3
Thanks for the answer! TONIGHT I will check up and I will write the answer
NickBahtin
Working!!!
Gepostet: 25.07.2011 - 16:01 Uhr  ·  #4
Thanks for your help. Earned only true option 1 (Disable the JTAGEN)
2. Disable_JTAGPORT revived the display - but it was broken. Most likely not true initialize display
Gepostet: 25.07.2011 - 17:05 Uhr  ·  #5
to use Disable_JTAGPORT you should place this statement in a SYSTEM_INIT procedure.
So the JTAG is disabled before any initalization takes place.
Note that you must not call this procedure from inside your application!
