Fehlermeldung Programmer
  • Seite 3 von 4
SM3XCS
Re: Fehlermeldung Programmer
Gepostet: 06.10.2010 - 18:05 Uhr  ·  #17
Hello, thanks for the answer..
No i have a swedish version of Win7.
I have the WinXP service pack 2 comp...... mode selected,
but no contact to the programmer :(
I´m gonna install it on another Win7 machine, lets see whats happen..
Regards Thomas
SM3XCS
Gepostet: 06.10.2010 - 21:46 Uhr  ·  #18
I have now tried to install AVRco on 3 computers, one with WinXP SP2 and i get the same error on all machines. "Programmers not found" . It installs ok everything and ISP-3 debug appears in the controlpanel with no errors, but E-LAB software can´t found it. :(
Edit:
Now the programmersoftware found the programmer!!!!
I had to download firmware to the programmer, and that worked, after that
the programmer shows up in the software, thats a good sign.. :D
070523_ISP3_Deb_Std_101.pupd ,, this firmware...
Now i got it all working.. :-)
Thanks Gunter for your help.
Regards Thomas
Gepostet: 07.10.2010 - 22:58 Uhr  ·  #19
Hi Thomas,
OK. This is the most recent version for your programmer.
I am happy, youself found the solution and I don't have to
investigate in a Swedish Windows. :-)
(several years ago I had to support servers at Mazda Europe ->
Japanese Windows. This was a real challange! :sick: )
Jest
Gepostet: 16.11.2010 - 09:37 Uhr  ·  #20
Hello Gunter,
looks like, I will need help too. I am using WIN7, 32 bit. Till month ago, everything was perfect - no nonsens with "programmer not found". Then it became - once a day, three times in row, on few hours - and medicine was clear: unplug, wait and plug it back. It was the same today when I repeated this for two times. Third time I go message that device is not recognized. I switched to another USB port but again same message. Then I tried dongle from my coworker but again samo message - so it looks like, HW is not the problem. Then I uninstalled, installed,... but without any luck.
And I need to do my work... :'(
Best regards,
Andrej
Gepostet: 16.11.2010 - 15:25 Uhr  ·  #21
Hi Andrej,
what's about the other test:
your programmer at your coworker's PC?
Does it work there?
Jest
Gepostet: 16.11.2010 - 15:34 Uhr  ·  #22
excellent idea but we didn't try it. And now he is not around any more for two days so I would need some other solution... :-|
Best regards,
Andrej
Gepostet: 16.11.2010 - 15:49 Uhr  ·  #23
there are no special issues with Win7/32 known.
You should
- uninstall the driver and select "remove files from disk".
- disconnect the programmer and connect it again.
- Win should then NOT be able to locate a driver for the "new device"
- just to be sure install the driver MANUALLY:
select ..E-LAB/AVRco/USB2_Driver/ELABDRV2.INF
If you change the USB port on the PC Win usually asks again for the
driver. But in this case "automatic installation" works.
Jest
Gepostet: 16.11.2010 - 17:44 Uhr  ·  #24
Hello Gunter,
and sorry Gunter, but I have no luck and a day lost searching way to get dongle on line.
I did all you wrote, many times, I even restarted computer but there is always Windows message, that USB device is not recognized. And when I wanted to update driver from AVRco USB path, there is message, that device is not working.
Funny thing is, that everything worked, even today I made compile two times....
Any idea about next step?
Best regards,
Andrej
  • Seite 3 von 4
