IRQ and procedure
How to start procedure from IRQ
Jest
IRQ and procedure
Gepostet: 21.09.2010 - 12:46 Uhr  ·  #1
Hello,
I have situation with xMega, when there is interrupt on one of input pins and then I should start procedure - almost immediately. If the procedure is called in interrupt routine, it is not OK – system hangs from time to time. Setting flag and then checking this flag in main loop is not OK – I never knows when the procedure will be started. Now, I am lost. :(
Is there any other method to do this? And I don’t want to import multitasking.
What if I still run procedure from interrupt routine, what should be the stack? Frame? Any other settings?
Tnx for help,
Andrej
Re: IRQ and procedure
Gepostet: 21.09.2010 - 13:46 Uhr  ·  #2
Hello Andrej,
it seems that you accidently destroy some registers in your interrupt service. To avoid this use complete register saving for interrupts or manually save the used registers by PUSHs and POPs.
