Forward Declarations
Gepostet: 10.08.2010 - 14:24 Uhr  ·  #1
@ Rolf.
In the compiler manual the following is described
type TPtr = pointer; forward; // preliminary declaration
TRec1 = record
Ptr1 : TPtr;
TPtr = pointer to Trec1; // main declaration
(I have removed "...")
This does not compile - I get the error "Error: Duplicate declaration".
Merlin.
p.s. I should have said that this is in the interface section of a unit.
pps Here is a work around. Maybe manual needs to be changed? It is more logical any way:
type TRec1 = record; forward; // preliminary declaration
TPtr = pointer to Rec1;
TRec1 = record
Ptr1 : TPtr;
This compiles OK
Re: Forward Declarations
Gepostet: 11.08.2010 - 21:18 Uhr  ·  #2
Hello Merlin,
ok, the first failure is a limitation. But I'm pretty unsure what I can write into the manual to warn the user...
Gepostet: 12.08.2010 - 09:43 Uhr  ·  #3
Hi Rolf.
Just give a different example, (i.e. one that compiles) such as my work-around. As long as there is a way and the example is valid I think that is fine, but there should not be an example in the manual that does not compile.
Cheers
Merlin.
Gepostet: 12.08.2010 - 20:31 Uhr  ·  #4
Hello Merlin,
where did you find this bad sample?
Gepostet: 13.08.2010 - 09:41 Uhr  ·  #5
Hi Rolf.
It is in DocuCompiler.pdf section 4.1.17 - page 33, and then again on page 71 (I also noticed a typo, Funktion instead of Function an that page).
Merlin.
Gepostet: 13.08.2010 - 13:20 Uhr  ·  #6
Hello Merlin,
thank you.
