Receiving data via TINA
nwrightson
Herkunft: Newcastle
Homepage: nweha.homeserver.c…
Gepostet: 30.07.2007 - 07:50 Uhr  ·  #1
The Doc's in this area do not say anything and the examples do not show actual reception of data.
I have tried looking at the Wiznet Server examples and these make sense to me but do not apply to the TINA.
1) How do I receive data in via the TINA interface.
2) What is the difference between TinaRxStat and TinaPacketReceived
3) How do I check to find the status of the connection state?
I tried "ErrorState" but do not get valid status reported back.
I can transmit data to the PC and have actually received it :)
But it would be nice to know that I have actually established a connection to a PC.
Slightly different question. Why use a different Port for Tx then Receive? Why not the same port in & out?
FvMP
Re: Receiving data via TINA
Gepostet: 30.07.2007 - 08:47 Uhr  ·  #2
Hello Neil,
regarding "connection status": A status doesn't exist for the connectionsless UDP protocol. The E-LAB proprietary xUDP-protocol should set STimeOutErr if the peer isn't responding.
Regards,
Frank
Gepostet: 30.07.2007 - 12:02 Uhr  ·  #3
Hello Frank,
Hello Neil,
yes, UDP has no connection state like TCP/IP. As Frank said, with xUDP you
can find out that the recepient is not reachable. With standard UDP this is not
possible. It is the job of the application to establish a "connection".
TinaRxStat and TinaPacketReceived are similar. The first doesn't change anything
in the Tina Stack. The second one changes the state of the stack.
The first one should be used for polling. The second one is the first to be used
when receiving a packet.
nwrightson
Herkunft: Newcastle
Gepostet: 30.07.2007 - 12:14 Uhr  ·  #4
Hi Rolf,
Thanks for the reply.
What state are you talking about? How is it changed?
Is it like SerStat?
I still don't understand how to get the data.
In the Wiznet a loop is performed to read the data one byte at a time from the wiznet chip into the AVRco buffer and then the buffer is copied out based on the number of bytes copied from the wiznet buffer to our buffer.
How does the TINA work?
Could you give an example of populating a target string from the buffer?
How do we know how big the string is to copy?
Any thoughts on the socket number question?
Gepostet: 30.07.2007 - 12:24 Uhr  ·  #5
Hello Neil,
with PacketReceived an internal state is set that (when true) the next access
will be the data read operation. The TinaRxStat doesn't disable interrupts, the
packetreceived does.
The TINA automatically transfers the received data to you buffer in the app
when ResumeReceive was previously executed. Your data then is in your
RxBuffer.
nwrightson
Herkunft: Newcastle
Gepostet: 30.07.2007 - 12:34 Uhr  ·  #6
Ah,
Starting to make sense now :)
Nothing like Wiznet, much simpler :)
Is the data transferred before or after the ResumeReceive?
Before I would presume.
I will give this a go at work in the morning.
Thanks Rolf.
Gepostet: 30.07.2007 - 13:03 Uhr  ·  #7
Hello Neil,
"ResumeReceive" tells the TINA that the present data in the buffer is processed
now and can be overwritten by a new packet. It means "the application is ready
to receive a new packet now".
Then polling the TinaRxStat returns the info if there is a new packet in the
buffer.
nwrightson
Herkunft: Newcastle
Gepostet: 31.07.2007 - 01:52 Uhr  ·  #8
Hi Rolf,
Couple more questions
1) How do I determine the size of the message that has been received?
2) How do I determine what IP address the message came from in order to reply to this connection.
