Compiler bug?
  • Seite 2 von 3
Re: Compiler bug?
Gepostet: 28.08.2021 - 13:39 Uhr  ·  #9
Thanks miparo.
Fix attached.
This type of testing is exactly what I need to help me maintain the software, so thank you again.
Re: Compiler bug?
Gepostet: 28.08.2021 - 22:54 Uhr  ·  #10
Hi Merlin,
thanks great job :)
But strings are not accepted.
And all other types please test :) :)
tParmRecX = record
eProjectName : String[12];
parX : array[0..59] of byte;
ParmRecX[@parX] : tParmRecX;
ProgName : String[12];
ProgName := ParmRecX.eProjectName;
Re: Compiler bug?
Gepostet: 29.08.2021 - 11:39 Uhr  ·  #11
Hello Merlin,
you should only make the updates available in one place / thread.
Otherwise it is a little confusing.
Great job :)
Re: Compiler bug?
Gepostet: 29.08.2021 - 12:38 Uhr  ·  #12
Hi Miparo
Fix attached.
This is of course not possible.
The best I can hope to do is batch test all demo programs (although that will of course only pick up compile issues, not run issues) but that is of course very time expensive. I will look into how I can do batch runs.
Re: Compiler bug?
Gepostet: 29.08.2021 - 12:43 Uhr  ·  #13
@Harry
I agree, but this is temporary.
I am trying to build an installer that will run on the main site. It is clear though that I need to build a full install first, which is a shame, as there are several hundred files. And of course I will need to test.
So please bear with me for a while :-)
Re: Compiler bug?
Gepostet: 29.08.2021 - 20:25 Uhr  ·  #14
Zitat geschrieben von Merlin
Hi Miparo
Fix attached.
Hi Merlin,
Sorry. I meant the other types in the record.
Int,Float .....
and the next bug :)
Unit Comptest;
interface
tParmRecX = record
xProgVerStart : word;
eProjectName : string[12];
{ Var Declarations }
{ functions }
implementation
// local part
{ Type Declarations }
TWzSocket = record
inherit tParmRecX;
This happens only in a unit when the two records are separated by interface/implementation
Re: Compiler bug?
Gepostet: 30.08.2021 - 09:29 Uhr  ·  #15
Some time ago I've researched unit testing frameworks which could be used in microcontroller world. TAP looked like a good candidate which could be adapted for using MCU serial output stream as a test result (AvrCo simulator serial output stream?). With some effort even continous integration should not be that far away. This automation could save time needed for testing in the long run.
http://testanything.org
https://sourceforge.net/projects/tap4pascal/
Re: Compiler bug?
Gepostet: 30.08.2021 - 09:42 Uhr  ·  #16
Thank Avra, I will look into this.
  • Seite 2 von 3
