eeprom record passed as a function parameter
Re: eeprom record passed as a function parameter
Gepostet: 29.05.2015 - 13:36 Uhr  ·  #9
Hello Merlin,
This is perfectly valid for compiler:
  if TEnum(One) > TEnum(Zero) then
    nop;
and my code is no different, except that one var is in eeprom.
I respect your argument for disliking such enum comparison, but there is a reasonable case when such thing is needed and compiler should let me do it with eeprom vars when it lets me do it with ram vars. For example, I have an engine which triggers various TAlmLogLevel events of different importance like here (enums prefered over constants in this case):
  TAlmLogLevel  = (evIrrelevant, evNormal, evImportant, evCritical);
Then I have a user setting stored in eeprom which filters what events shall be stored into flash memory. So, it is perfectly legit to compare event type with user defined filter (of the same type). Therefore I would still like it to be allowed without need for a workaround.
Gepostet: 29.05.2015 - 14:15 Uhr  ·  #10
As I say, Avra, more a comment than anything else. I think that
if byte(One) > byte(Two) then
is perfectly OK. You are accepting that your set is ordered.
I don't like
if One > Two then
I can see an argument for
if TEnum(One) > TEnum(Two) then
because you then do not need to know the size of the underlying variable, so I am happy with that too. So I agree, your first work around should work, although I would still argue the original construct should not be valid.
