Problem mit Simulator
  • Seite 2 von 4
Re: Problem mit Simulator
Gepostet: 23.12.2011 - 19:32 Uhr  ·  #9
I will take a look.
In meantime, you can examine the attachment. I am sure it will be interesting to you since it's an AvrCo astronomy project (telescope GOTO positioner). It is basically an AvrFreaks project from http://www.avrfreaks.net/index…pe=project, but since then author has changed the compiler and you can no longer find it on his site. SkyCharts 2.76 is made with AvrCo astronomy application in mind, and if you want it but can't find it then PM me with your e-mail address and I will send it to you. You can also take a look at this: http://forum.e-lab.de/topic.ph…hlight=sun.
Dateiname: Astronomy telescope  … ioner.7z
Dateigröße: 1.93 MB
Titel: AvrCo telescope GOTO positioner
Heruntergeladen: 143
Gepostet: 24.12.2011 - 01:18 Uhr  ·  #10
Root of the problem was found and I have prepared all the details for Rolf. You will hear from him soon if my results are confirmed.
Your VARIABLEN.PAS has some constants already delivered with uFix64 library. This is from the library:
  FIX_INT_DIGITS: byte = 10 + 1; // number of digits used for representation of integer part plus 1 digit for sign
  FIX_FRACT_DIGITS: byte =  9;   // number of digits used for representation of fractional part
  FIX_MAX_STRING_LENGTH: byte = FIX_INT_DIGITS + 1 {decimal point} + FIX_FRACT_DIGITS; // 21 is max length of all strings that contain fixed point numbers
  FIX_MAX: fix64 = Max(int64); // biggest number  $7FFFFFFFFFFFFFFF =  2147483647.999999999
  FIX_MIN: fix64 = Min(int64); // smallest number $8000000000000000 = -2147483648.000000000
  FIX_ONE: fix64             = 1.00; // number neutral in multiplication and division
  FIX_ONEHALF: fix64         = 0.50; // int64(FIX_ONE) div 2;
  FIX_ONEQUATER: fix64       = 0.25; // int64(FIX_ONE) div 4;
  FIX_ONETHREEQUATERS: fix64 = 0.75; // FIX_ONEHALF + FIX_ONEQUATER;  // 3*FIX_ONE/4
  FIX_PI: fix64              = 3.141592654; // 3.14159265358979323846264338327950288 I know this is a little too much ;-)
  FIX_PIHALF: fix64          = 1.570796327; // int64(FIX_PI) div 2;
  FIX_PIQUATER: fix64        = 0.785398163; // int64(FIX_PI) div 4;
  FIX_PITHREEHALFS: fix64    = 2.356194490; // FIX_PI + FIX_PIHALF;
  FIX_PITWO: fix64           = 6.283185307; // FIX_PI + FIX_PI;
  FIX_180: fix64             = 180.0;
  FIX_90: fix64              =  90.0; // int64(FIX_180) div 2;
  FIX_360: fix64             = 360.0; // FIX_180 + FIX_180;
  FIX_E: fix64               = 2.71828182845904523536;
Btw, do you really have LX200? :love:
I have always wanted to connect astronomy application to some DIY step motor based telescope, but the best I did so far was to run Stellarium from netbook and teach my twins stars in the sky. That was real fun with images from this software:
Gepostet: 24.12.2011 - 16:13 Uhr  ·  #11
Hello Avra, Thomas,
the simulator is the problem here. After a 64bit compare a flag gets destroyed and the result becomes invalide. In this special case (Fix64Sin) the program enters an endless loop.
Bug is fixed now. Update next week.
btw.
The generated code is ok and will work in real hardware.
Herkunft: Gera
Gepostet: 26.12.2011 - 10:48 Uhr  ·  #12
ich hoffe, Sie hatten und haben trotz all der Arbeit ein besinnliches Weihnachtsfest.
Gerade habe ich die Version 4.99.65 installiert und kurz angetestet.
Das Problem mit den Leerzeichen im Pfad zu den PCU-Dateien besteht leider noch.
Ich habe ein leeres Projekt mit einem XMega angelegt und nur FAT16 eingebunden.
Das Projekt kompiliert ohne Probleme. Beim Start des Simulators kommt zuerst die Meldung
Project Date/Time has changed! Reload File?
Wenn ich dort "Cancel" anklicke, folgt
File c:\program not found
Wenn ich "Yes" anklicke, werden es ein paar Fehlermeldungen mehr.
Mein AVRco ist unter "C:\Program Files (x86)\AVRco" installiert (Win 7 64 bit).
Ich habe nun eine Kopie des Verzeichnisses "C:\Program Files (x86)\AVRco\AVRco\System"
in welchem die *.pcu-Dateien liegen erstellt. Der Pfad ist "E:\AVR-Projekte\_System".
Wenn ich in der Datei "XMega.u" nun die Zeile
FILE c:\program files (x86)\avrco\avrco\System\UFAT16.PCU UNIT;29;
in
FILE e:\avr-projekte\_system\UFAT16.PCU UNIT;29;
ändere, startet der Simulator ohne Probleme.
Ich denke, dass die Leerzeichen im Pfad dazu führen, dass der Simulator statt der Datei "c:\program files (x86)\avrco\avrco\System\UFAT16.PCU" nur "c:\program" zu laden versucht und damit logischerweise auf die Nase fällt.
Mit besten Wünschen für einen Guten Rutsch ins neue Jahr
Dateiname: XMega-Test.zip
Dateigröße: 346.05 KB
Titel: Testprojekt
Heruntergeladen: 125
Gepostet: 26.12.2011 - 16:10 Uhr  ·  #13
das Problem ist mir inzwischen bekannt, aber ich hatte mich im letzten Update auf das XMega Compare und das XMega Application codesize Problem konsentriert. Das Pfad Problem mit den Spaces ist im nächsten Update auch erledigt.
ein schönes, gesundes und erfolgreiches Neues Jahr an alle User
a happy, successful and healthy new year to all users here
ThomasW69
Gepostet: 02.01.2012 - 13:54 Uhr  ·  #14
Hallo Zusammen.
Ich wünsche allen Forenmitgliedern erst mal ein gesundes neues Jahr 2012.
Gerade habe ich mir das aktuellste update heruntergezogen. Leider bekomme ich eine Fehlermeldung beim Compilieren meines Codes
internal assembler error 82341
Danach wird angezeigt, dass
Error:Code exceeds romsize: 20CCFh > 1FFFFh
Das war vorher nicht so. Mit dem Merlin Optimiser kann ich es compilieren und im Simulator läuft es auch. Woran kann der neue Fehler jetzt liegen?
Gepostet: 02.01.2012 - 15:48 Uhr  ·  #15
das ist die typische Meldung, wenn der Code größer als der Flash-Speicher des angegebenen Controllers wird. Da hilft nur Code kleiner machen oder mit dem Optimizer arbeiten.
Du kannst ggf. die folgenden Direktiven aktivieren (die Blanks hinter { herausnehmen), um den Optimizer anzuweisen, weniger zu optimieren:
{ $OPTI SMARTLINK_ONLY} // This is a quick Optimizing to throw out unused procedures and functions
{ $OPTI_QUICK} // This makes only one Optimization Loop
Gruß, Michael
Gepostet: 02.01.2012 - 20:32 Uhr  ·  #16
weiter oben steht:
the main problem here is that with an XMega128 the application flash ends at $1FFFF and the flash above this address is used as a Boot ROM. The AVRco always expects that the application+constants end below the Boot area. With your application the application exceeds the border to the boot area.
This is valid for the XMegas but the AVRco doesn't support this border crossing at this time.
One of the effects is that the string constants are not in the page as expected. Using the Merlin Optimiser the code size is heavily reduced and this limit is not axceeded.
Und im neuesten AVRco readme file
XMega
Bug in Simulator fixed.(XMega 64bit compare).
Application codesize limit reduced. Boot area excluded.
  • Seite 2 von 4
