Receiving data via TINA
  • Seite 2 von 3
nwrightson
Herkunft: Newcastle
Homepage: nweha.homeserver.c…
Re: Receiving data via TINA
Gepostet: 31.07.2007 - 02:05 Uhr  ·  #9
My understanding of UDP is that messages can be sent in a broadcast format as well as specifically to IP address.
Can we detect these two different types of inbound messages?
I.e. a) Flag to say it was a broadcast
b) address of sender
Gepostet: 31.07.2007 - 11:43 Uhr  ·  #10
Hello Neil,
the received byte count can be found here:
socket^.PacketRecInfo.RecLen
the sender IP address is here:
socket^.PacketRecInfo.PeerIP
Because I didn't use Broadcasts until now I'm not sure if there is a RxFlag for
Broadcasts.
But Broadcasts can be identified by their PeerIP consisting of all $FF
nwrightson
Herkunft: Newcastle
Gepostet: 31.07.2007 - 12:12 Uhr  ·  #11
Hi Rolf,
Sorry to be a pain with all of the questions.
Thanks for the feedback.
Hopefully it will all be working tomorrow.
AV
Gepostet: 26.11.2012 - 18:06 Uhr  ·  #12
This topic is 5 years old, but there is still a lack of documentation.
I want to receive UDP packets by TINA and read the profi driver manual and the example AVR TINA_ENC_UDP. More specific information (about my task) I couldn't find in the forum and internet.
In general the AVR example is nice. Unfortunately it doesn't tell how to read out the received data in detail.
Configuration of example:
  //Construct the first Socket  (xUDP)
  UDP := TinaCreateSocket;
  With UDP^ do
    Protocol:= pxUDP;
    LocalPort:= 8000;
    RemotePort:= 1000;
    RemoteHost:= IP;
    PacketRecInfo.BufferPtr:= @MyBuf;
    PacketRecInfo.BufferLen:= SizeOf(MyBuf);
  endwith;
Receiving code of example:
    //Socket UDP
    if TinaPacketReceived(UDP) then
      //We receive a packet @Socket UDP
      //We do nothing so dont block the Socket with trash! Lets resume !
      TinaResumeReceive(UDP);
I suppose the received data is stored inside of PacketRecInfo.BufferPtr.
Questions:
1.
How to read out the buffer?
I suppose the content is a Byte array with the length BufferLen, which I have to convert to my wanted values.
Great would be an example how to read 4 bytes from the buffer (which I can convert to a Float type).
2.
What happens if the micro controller received 2 or more packets?
Is there only the next packet content in BufferPtr or the content of all received packets?
What I want:
For my application I want to receive UPD packets with a byte list, which represents a "frame" of several values (Bytes, Floats and Integers). After reading the Byte array, I want to convert sub-arrays to the related types.
Gepostet: 26.11.2012 - 18:38 Uhr  ·  #13
Hello AV,
yes, BufferPtr points to the received data.
Profi Manual pg. 121:
Type
TtinaPacketReceive = Record
   PeerIP : tIPaddr;
   PeerPort : Word;
   RecLen : Word;
   BufferPtr : Pointer;
   BufferLen : Word;
If data is received then "RecLen" contains the byte count of the reception.
Data must be read out with
x:= PacketRecInfo.RecLen;
while x > 0 do
  d:= PacketRecInfo.BufferPtr^;
  dec(x);
endwhile;
TinaResumeReceive(socket);
Of course "d" can be another pointer etc.
The socket is blocked until you have re-enabled it with:
AV
Gepostet: 27.11.2012 - 17:12 Uhr  ·  #14
Thanks for your answer (-:
What happens by this line of code?
Does it read one Byte from the buffer and moves the pointer to the next position automatically?
In this case I hope I can convert the encoded value like this:
FUNCTION GetFloatFromBuffer(var pRecInfo :tTinaPacketReceive) :Float;
  flo    :Float;
  bytes  :Array[0..3] of Byte;
  bytes[0] := Byte(pRecInfo.buffPtr^);
  bytes[1] := pRecInfo.buffPtr^;
  bytes[2] := pRecInfo.buffPtr^;
  bytes[3] := pRecInfo.buffPtr^;
  flo := Float(bytes);
  return(flo);
FUNCTION GetIntegerFromBuffer(var pRecInfo :tTinaPacketReceive) :Integer;
  itg    :Integer;
  bytes  :Array[0..1] of Byte;
  bytes[0] := pRecInfo.buffPtr^;
  flo := Integer(bytes);
  return(itg);
And these helper functions I can call like this:
if TinaPacketReceived(udp) then
  // parse the data of the UDP packet
  myByte := PacketRecInfo.BuffPtr^;
  myFloat := GetFloatFromBuffer(var PacketRecInfo);
  myInteger := GetIntegerFromBuffer(var PacketRecInfo);
Gepostet: 27.11.2012 - 21:08 Uhr  ·  #15
Hello AV,
pointers are never automatically incremented. If you want this then use:
d:= PacketRecInfo.BufferPtr^++; // auto increment after transfer
Also using an array for the destination introduces an overhead for array indexes.
Use this:
  itg : integer;
  b0[@itg] : byte;
  b1[@itg+1] : byte;
  b0:= pRecInfo.buffPtr^++;  // low byte of itg
  b1:= pRecInfo.buffPtr^++;  // high byte of itg
reading a float is similar.
AV
Gepostet: 03.12.2012 - 12:29 Uhr  ·  #16
Hello Mr. Hofmann,
thanks again for your notes (-:
Now I wrote my parser functions in this way:
  itg           :Integer;
  byte0[@itg]   :Byte;
  byte1[@itg+1] :Byte;
  byte0 := pRecInfo.buffPtr^++;  // low byte of itg
  byte1 := pRecInfo.buffPtr^++;  // high byte of itg
  return(itg);
//FUNCTION GetFloatFromBuffer(var buffPtr :Pointer) :Float;
  flo           :Float;
  byte0[@flo]   :Byte;
  byte1[@flo+1] :Byte;
  byte2[@flo+2] :Byte;
  byte3[@flo+3] :Byte;
  byte0 := pRecInfo.buffPtr^++; // lowest byte of float
  byte2 := pRecInfo.buffPtr^++;
  byte3 := pRecInfo.buffPtr^++; // highest byte of float
  return(flo);
(Currently I can't test it, because I still have trouble with TINA, which I want to use in an additional file/unit.)
For security reasons the last Byte of my UDP packets contains value 255.
So I can perform a quick check for the expected length.
How shall I read the last Byte of the packet?
// Sicherheitsprüfung (letztes Byte im UDP-Paket muß 255 sein)
if PacketRecInfo.BuffPtr^++ <> 255
Or just write BuffPtr^ without ++?
Reason: Perhaps the ++ could create an exception, when the buffer size is equal to the packet size.
I asked this, because you wrote this code, which doesn't increment the pointer.
Additionally I remember a discussion about a C++ line of code, which increases automatically by reading.
while x > 0 do
  dec(x);
endwhile;
Do you mean, the receiving is blocked directly after the first packet?
So there would be never more than 1 packet inside of the buffer.
Is it right?
(In the manual of the profi driver there is no information about such details.)
Sincerely yours
Andreas
  • Seite 2 von 3
