// ********************************************************************** // This application runs completely in the boot section of the AVR. // Some library functions and drivers are used and also interrupts // are running. If the FlashDownloader is started then also here // the standard interrupt driven UART/SerPort is used for communication. // Please note that the constant "BootCheckF" is placed to a fixed // address, but is outside of the boot area. A valid main application // residing in the "normal" code area $0000 and up must provide this // constant in order do an immediate jump to $0000 into the standard // application area. // The Main Application must be build and compiled separately and can // be downloaded with this Application/Bootloader // ********************************************************************** program BootAppM168; {$NOSHADOW} { $WG} {global Warnings off} Device = mega168, VCC = 5; {$BOOTAPPLICATION $01c00} // 8kByte Boot size define_fuses Override_Fuses; NoteBook = A; COMport = USB; LockBits0 = []; FuseBits0 = [CKSEL3, CKSEL2, CKSEL0, SUT0, CKDIV8]; FuseBits1 = [BODLEVEL1, BODLEVEL0]; FuseBits2 = [BOOTSZ1, BOOTSZ0, BOOTRST]; ProgMode = SPI; ProgFuses = true; ProgLock = true; ProgFlash = true; ProgEEprom = true; // AddApp = 'c:\PROJEKTE\Pascal_sc\AVR\EvaBoard\AVR EvaBoardI'; // Info for programmer, joining hexfiles, using this project name import SysTick, FlashWrite, SerPort; from System import Traps,FlashCheck_A; define ProcClock = 4000000; {Hertz} SysTick = 10; {msec} StackSize = $0030, iData; FrameSize = $0064, iData; SerPort = 19200, Stop2; {Baud, StopBits|Parity} RxBuffer = 8, iData; TxBuffer = 8, iData; FlashChkSum = $37fe; implementation {$IDATA} {--------------------------------------------------------------} { Type Declarations } type {--------------------------------------------------------------} { Const Declarations } const // BootCheckF[$37FE] : word = $AA55; // in the standard app area BootCheckF[BootEntry -4] : word = $AA55; // in the standard app area DownLoaderID : word = 1234; DownLoaderPWD : word = $ADBB; // FlashChkSum[BootEntry-2] : word = $ffff; // Programm Ende cStr : string = 'BootApp started'; {--------------------------------------------------------------} { Var Declarations } {$IDATA} var st : string[10]; {--------------------------------------------------------------} { functions } procedure BootTest; begin if BootCheckF <> $AA55 then FlashDownLoader; endif; // It is also possible to check a port pin so that the // user can force a new download.... end; procedure FlashLoaderInit; begin EnableInts; // because the Downloader disabled it FlushBuffer(RxBuffer); // ... end; procedure FlashLoaderRecv; begin asm: Push _ACCB asm: Push _ACCALO asm: Push _ACCCLO asm: Push _ACCCHI _ACCA:= SerInp; asm: Pop _ACCCHI asm: Pop _ACCCLO asm: Pop _ACCALO asm: Pop _ACCB end; procedure FlashLoaderTransm; begin asm: Push _ACCB asm: Push _ACCALO asm: Push _ACCCLO asm: Push _ACCCHI Serout(_ACCA); asm: Pop _ACCCHI asm: Pop _ACCCLO asm: Pop _ACCALO asm: Pop _ACCB end; procedure FlashLoaderExit; var bc : byte; begin // now calc the application checksum repeat bc:= CalcFlashCheck_A($ff); // until bc <> 0; case bc of 1 : // check ok Application_Startup; // enter the main application | 2 : // check failed ! // what shall we do now ? // jump to the Downloader ? FlashDownloader; | endcase; end; // lösche BootFlag und Restart procedure StartFlashLoader; Trap; begin FlashInitPage(addr(BootCheckF)); FlashErasePage; System_Reset; end; {--------------------------------------------------------------} { Main Program } {$IDATA} begin // if the BootTest fails it enters the FlashDownloader BootTest; // if the BootTest was valid then normally this Boot Application // should jump to the Main Application entry $0000 with this procedure: // This part is only for demonstration of the BootApp functuality EnableInts; Writeln(Serout, cStr); loop if Serstat then SerInp; endif; endloop; end BootAppM168.
